Hi there
I'm a bit confused about what to do about this.
I bought a second hand PCU13 back in 2008, it was iirc about 18 months old at the time. After I got it home I found that after unplugged it would take about 15 minutes for it to power up again. If left on standby there were no problems.
I then found this was a known issue with some early models
Ultra amps & their 2 minutes of "OFF TIME" ?? | AVForums
I didn't bother to do anything about it as it never caused me any problems. As I said when on standby there were no issues at all and if I did unplug to move it around after 15 minutes it would always fire up.
I used it from 2008-2013 and it has performed faultlessly, since then it's been stored because I'm having building works done on my house.
Anyway I now want to sell it as I want to go in a different direction when I hopefully have a new dedicated room.
I thought it might be worth replacing the amp so as not to put off any prospective buyers. I contacted LSound to see whether they could help in anyway but given it's well out of warranty they can't offer me any concessions of any kind. They will sell me a new amp but at a cost of circa 600 euros.
I'm assuming it's not worth replacing the amp at that kind of cost in terms of resale value?
So should I just sell making the buyer fully aware of the issue? How should I adjust the asking price?
Just to be clear, the only issue with it is this 15 minute lag when unplugged, apart from that it works perfectly.
Thanks for your help
