Hi All At present I am using a Samsung 17 Widescreen monitor which I am very happy with,However,having just bought GT4 for the Playstation,I need /want a widescreen LCD TV to replace the Samsung so I can connect said Playstation and also use it as a Computer Monitor. Can someone tell me what a minimum spec would be for an LCD TV for this kind of use,I will also play a few DVD's via the computer. Thanks Alan
i just fot the sharp aquos 26ga4e for the same purpose. has scarts, components, dvi etc, good stuff, if u can find one!
and this one Sharp LC-32GA5U 32 in. HDTV-Ready LCD Television: Product Features (choose a different model) Sharp¿s LC-32GA5U AQUOS¿ is a state-of-the-art 32" widescreen LC-TV that can easily enhance the decor of any family room, living room or den. With a 16:9 aspect ratio, HDTV-compatible resolution of 1366 x 768 and breathtaking color purity, it is a next-generation TV to carry you into the high-definition future. Key Features Flat Panel Type LCD Screen Size 32 inch Digital TV Standard HDTV Monitor / HDTV-Ready Display Resolution 1366 x 768 pixels Display Capabilities Display Format 1080i (HDTV), 720p (HDTV), 480p (EDTV), 480i (SDTV) Digital TV Standard HDTV Monitor / HDTV-Ready - Requires separate receiver to view HDTV signals. Aspect Ratio 16:9, 4:3 Enhanced Remote Control Remote Control Multibrand Image Quality Comb Filter 3DYC / 3D Digital Display Resolution 1366 x 768 pixels Brightness 450 cd/m Output Color 16.77 million colors Viewing Angle 170 Adjustable Color Temperature With Adjustable Color Temperature Audio Features Audio Type Virtual Surround Audio Output Variable / Fixed MTS Stereo With MTS Stereo Secondary Audio Programming (SAP) With SAP Technical Features Picture in Picture Without PIP Parental Control V-Chip Sleep Timer With Sleep Timer Energy Star Compliant Energy Star Compliant Connectors Rear Input Connectors S-Video x 1, Component x 2, Composite x 3, DVI x 1, HDMI x 1, Audio (RCA) x 4, RF x 1 Rear Output Connectors S-Video x 1, Composite x 1, Audio (RCA) x 1 Headphone Jack With Headphone Jack Screen Text OSD Languages English, French, Spanish Channel Labels With Channel Labels Speakers Number of Speakers 2 Speakers Speaker Power 2 x 10 Watt Dimensions Width 38.58 in. Depth 4.25 in. Height 18.89 in. Weight 36.4 lb. Warranty Overall Warranty 1 Year Miscellaneous Cabinet Color Silver Included Accessories TV Stand, Remote Control Batteries Product ID 23209325
That sounds like an US American spec to me. The European version does not have any digital inputs. -Ian
Not enough information to know whether US spec will accept European voltages, 50Hz and PAL support and european analogue tuner settings. I wouldn't like to risk the freight even if the specs and import costs checked out OK. -Ian
