What to Buy??
Discussion in 'Home Cinema Buying & Building' started by CrazyK, Jun 13, 2005.
  1. CrazyK
    CrazyK
    Im looking at buying a powerful but compact system for my bedroom, I want something that can play CD/DVD's etc and have a built-in Tuner and Surround sound.
    I was looking at spending between £200-£300 and quite like the Pioneer DCS 242, Has anyone had any dealings with this particular package- is it any good or is there better on the market for the same money ??
    Cheers for any advice
    K :confused:
  2. LG Chet
    LG Chet
    Nov 23, 2004
    125
    Ive got the Pionner DCS-333, just mounted the speakers onto my walls, looks and sounds excellent
    Edit: forgot to mention it cost £235 from RGB Direct :thumbsup:
  3. Darko
    Darko
    Apr 13, 2005
    4,037
    Caterham on the hill Surrey
    +199
    Check out richer sounds they normally have a good selection of these systems and super cheap.
    Woop Woop
    Darko
  4. Darko
    Darko
    Apr 13, 2005
    4,037
    +199
  5. pionstuff
    pionstuff
    Excellent choice
  6. Darko
    Darko
    Apr 13, 2005
    4,037
    +199
    lol
