What to buy
Discussion in 'Home Cinema Speakers' started by Mell0, Mar 3, 2005.
  1. Mell0
    Mell0
    Hiya lads & lasses
    I would like some advice on a home entertainment system to be used for both music and cinema. I have come up with the following system and would like some feed back on weather this is a good choice or not or if u have some other recommendations. From what I have read it seems have had some good reviews.
    Amp – Denon AV2105
    Speakers – KEF Q series
    Front – Q5
    Centre – Q9
    Rear – Q1
    Sub – PSW3000
  2. betamac
    betamac
    I have the Kef Q range and extremely impressed with them they look stunning and sound superb
    I had the PSW2500 Sub before i upgraded to the SVS and it was lacking a little, but the PSW3000 should be better with those speakers you chose
    I rang Hi Spek up for a price as they seem to be the cheapest, and if you live near enough then you can pick them up from one of there stores, i didn't so i got a local store to price match there price which they did :)
  3. Mell0
    Mell0
    Thanks for your advice it seems that I am on the right tracks do you think the amp would be able to provide enough power for the speakers
  4. Andrew K
    Andrew K
    Oct 14, 2004
    3,392
    +608
    The Q series are great for both music and home cinema.
    Although more expensive you may want to try out the Arcam AVR250 as an alternate amp if you want a musical side as well.
