What to buy???
Discussion in 'Plasma TVs Forum' started by JerryBolton, Nov 21, 2003.
  1. JerryBolton
    JerryBolton
    Aug 21, 2001
    Birmingham
    I have an old Tosh 32 widescreen tv. (Its massive and V heavy). Its started to play up with screen flickers and the like. I bought it as a grey import, so support from Toshiba is a non starter, I have to replace it. This is the story I've told my girlfriend. :devil:
    So, I'm interested in a plasma screen to replace the nasty heavy beast that sits in the corner of my room.
    I have sky+ and dvd inputs. I have a nice old amp (DD5.1) and speakers which I can run all my sound through. All I need is a nice new plasma screen. My drive is picture quality and sufficient inputs to connect sky, dvd and maybe my PS2. I am looking at value for money under £3k and availability before Christmas.
    Thanks for the help.
    Jerry
  2. Koing
    Koing
    Nov 21, 2003
    189
    16
    I'd say save another £200-£200 and go for the Panasonic TH42PA20B.
    Can be had for about £3300 with 3 scarts and a few other things.
    Will be easiest for you.
    Koing
  3. clouseau
    clouseau
    Hi Jerry,
    Sounds like you have enough related gear not to need a full TV.. just the screen - so how about a Panny 6 for £2600 inc wall bracket and delivery....
    you can buy me a pint with the change........
  4. ahh
    ahh
    Oct 13, 2003
    84
    London
    Hi Clouseau,
    Didn't realise that the Panny 6 is for £2,600. Is this a special deal somewhere? Inc wall bracket and delivery?
    Sounds like a good deal to me.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Pany PW6 with 1 scart board and 1 YUV board if DVD does YUV or 2 SCarts would be perfect and for £3k or less you wont get better! If 42 would be a bit big for your room then look at the Panny 37PA20 (37" only comes in PA guise.)
    CLouseau were have you seen panny 6 for £2600 inc bracket and delivery????
    To connect PS2 use AV2 on Sky and get a PS2 RGB cable if dont already have one!!
  6. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    You can get a 37" PW6 as a euro import, I'm sure I've seen one advertised somewhere. Warranty is not swap out unless the dealer backs it, but then this is the way it is in reality with panny stuff anyway, they've never had a loan screen that I've heard of. Not that they go wrong much anyway. But back to 42", the man has asked for a panel, and been recommended the best for his job. You won't be needing the component board, just a YUV to 15pin sub-d cable, saves you some money, if you want prog. scan on the dvd. Maybe with a JS rgb to YUV you could do it all by component switching, and have no video board at all. Easier for WAF as well, you might not need a pronto controller then.
  7. JerryBolton
    JerryBolton
    Aug 21, 2001
    Birmingham
    Thanks guys,
    Sounds like a Panasonic 42".
    I like the sound of the £2.6k inc delivery and brackets! Clouseau, I WILL buy you a beer if you can tell me where this deal is!
    And as I'm not 100% up on all this stuff, whats a component board vs a YUV to 15pin sub-d cable?!?
    Is this to do with auto switching between display formats? Because at the moment this is a pain in the neck. My Tosh TV does switch automatically when connected to the sky+ (only after various key combinations on the remote), but NEVER from the dvd or PS2.
    Or is this simply the best way to get good picture quality?
    My Tosh TV has 3 scarts and each of my 3 devices is plugged into one. The sky+ in SCART 1, DVD in scart 3 (as this has the digital audio input) and scart 2 is used for PS2 or the old vhs video.
    Thanks again in advance for the help. All appreciated.
  8. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    The panny has the ability to set the vga port to accept component video(YUV). You need no component board unless you want to use the PC input for something else, pc or a rgb-vga converter. Don't think you can autoswitch on a PW6 except via scart, universal remotes are popular for this reason!
  9. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,664
    UK
    +115
    Be aware that you lose "Just" mode by using the VGA connector IIRC - which some people like for 4:3 material
    JJ
