What to buy with my PWD7
Discussion in 'Plasma TVs Forum' started by Gedii, Mar 17, 2005.
  1. Gedii
    Gedii
    Hi all.
    I'm about to buy the 37" PWD7 from here :
    http://www.shootandshow.co.uk/pana-th-37pwd7.htm
    However I'm a bit confised with all terminal boards listed underneath.
    Do I actually need any of these or will the screen on it's own suffice?
    I plan to hook an NTL box anda DVD player to it.
    Thanks.
  2. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    well i expect it will just come with the vga input which could connect ntl to using scart to vga converter (do search on JS Technology)....if dvd has component out then the component board will be best bet (1st or 3rd in their table)...get some rca to bnc component cables too. If not scart board required. If you have dvd recorder and not just player you can route through that....also if you have an av amp there are other connection possibilities.
