Hi all,
Can you help please?
I have just bought a PV500 42" plasma. My intention was to wall mount it, however the only wall I could use meant I had to buy a bracket with an arm that would allow the TV to 'swing' out when I wanted to use it.
The problem is the bracket weighs a ton (about 80kg) and there is no way my wall would take it - it would pull the thing down.
So, I need to send that bracket back.
I am now thinking of just getting a stand for the TV, but I still fancy the idea of the TV being on an 'arm' so it can move out.
Has anyone seen such a design? Any links/ advice would be great.
Thanks.
Thanks.
