what to buy from currys philips ?
RON
My old tv a 33 inch square furgerson has died and i have £2000 to spend at currys dixonns it has to be spent there no where else.
I have looked ihave read through forum i have read what vid and what hifi and have looked again at which point i got tv blindnes saimilar to snow blindnes it makes all tvs from 14" to 42" look the same.
they do a package of the philips 36pw9607 low end dvd and a video rec which i quite liked although i was going to get a tosh 220 dvd.
I just would like some help as in what would you buy in the 36" 32 " range from them if you had to and what would be a good dvd low cost like tosh 220 210 with cheap amp and speaker from richer sounds say.
any idears and ifo will be apreciated as begining to go a bit mad .
By the way the 32 " selection is because im considering not spendig it all on a tv alone or at least the girlfriend has that idear.
J
jim.rae
Gosh - where to start...
If you buy from Curries, you should still be able to get the following package if you try - Samsung 42" rear projection TV, with Samsung DVD and VCR, plus a DTT set top box - probably Grundig.
That would cost around £1,700 which would leave you enough money to buy something nice from Richer Sounds for audio.
Check it out and tell the girl friend you need it for research purposes...
⭐ Bowers & Wilkins 600 S3 Home Theatre Speaker System Review
Back
