What to buy for £5K
Discussion in 'Blu-ray & DVD Players & Recorders' started by PaulHaggerty, Oct 19, 2004.
  1. PaulHaggerty
    PaulHaggerty
    I'm looking to upgrade my current AV system I have Wharfedale evo 40 speakers with the evo centre and rears, which I plan to keep.
    I want to spend around £5k for a dvd player (this will also be my main music source), AV amp and a plasma tv, I could push the boat out a bit if I had too but I would like to stay close to my target budget. Any advice please
  2. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,149
    Hampshire
    +76
    have you ever thoght of getting a projector like the panasonic ae700 instead of a plasma leaves you with more for the rest.
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,565
    Edinburgh
    +1,265
    £5k will get you a half decent plasma, and that's about it. As phillfy says, you should look at projectors, much better value for money.
  4. Tim Ashdown
    Tim Ashdown
    Sep 20, 2000
    639
    28
    East Sussex
    +87
    Its a good point about the projector but its not ideal for everyone. I wouldn't use one for everyday viewing like eastenders or the news. But I think £5000 could get you more than a half decent plasma... :)
    I would look at Av-Sales, £1650 with a free terminal board (maybe dvi) for a Panasonic 42pwd6 is a stonking deal. Then maybe a Denon A1SR for under 2K at various places, maybe less as its about to be replaced. And finish with a Denon 5900 for around £1.1k - £1.2. Even less if you went for a newer 3910. Sevenoaks are doing some good deals at the moment. That package should leave you with a couple of hundred to sort out some decent cables or wall bracket/stand. A package like that would be at home with movies and music.
    I'd be completely happy with the above package but you should have a few demonstrations. Equivalent gear from the likes of Pioneer/Yamaha/Rotel or others could be more to your liking, but certainly are available for similar prices.
    Or like you say you could push the boat out a bit and look at newer versions of what I've mentioned. Or more.... :D
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    What about the plasma as you suggest plus a Linn Unidisk SC @ £2995. By all accounts the Linn SC is a stunning DVD player with a built in processor that really does break the rule of 'separates are better'. All you need on top of the above would then be stand/bracket, amp(s), speakers and cables. I know this probably takes you over budget, but it will by all accounts be a great setup. I say 'by all accounts' as I have never seen the Linn Unidisk SC but have seen a few rave user reviews for it.
    Mark.
