what the heck is this?
Marc
I'm in the process of packing up all my stuff to move house, and i've come across the item pictured below, and i wondered if anyone knows what it is? Knowing my luck i'll throw it out and then find out i need it afterwards.. it's 22cm x 8cm and the two bits either side of the word "front" seem to be finger holes
Tempest
Well it's probably the battery cover for a radio or something like that.
Marc
i've just updated the first post with the dimensions, it's too big to be a battery compartment
Matt_C
If in doubt - melt it! :D
C225
If you wal mount the TV it goes underneath where teh stan would slot in
Marc
hmm well i guess mystery solved then, i doubt i'll ever wall mount it but i will keep hold of it just incase!
thanks!
its_all_Greek
thanks!
as others have said its off your sammy tv and its one of those items that if you keep it you will never use it but the minute you bin it you will want it and when you contact samsung to replace it they will tell you it will cost a ton to buy the replacement.:D
Member 55145
tell me about it, i accidently broke one of the prongs on my plasma stand, panasonic wanted £75 for a replacement prong!
fortunately wall mounts are cheaper :D
