what the best way
Discussion in 'Home Cinema Speakers' started by clancol, Nov 1, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    whats the bast way to set the phase on my sub. paradigm pw2200. i got some one to fiddle with the knob while i tried to see which position sounded strongest.( but im still undesided.)
    i have my mains set to large.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,129
    Rainham Essex
    +2,392
    I don't know how true this is, but somebody said to me......
    if the sub is facing the same way as your speakers then set phase to 0.
    If sub is facing towards the main speakers then set phase to 180.
    If the phase is a rotary control then set the phase setting to the same degree as the sub is angled from your main speekers.
    Mark.
  3. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    my Ms 908's have side fireing woffers built into the sides facing 90"
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,517
    Edinburgh
    +1,239
    Mark, what you have read was posted by myself. It is a rough starting point but not to be adhered to. Set the phase to the position suggested and then play about with settings either side of this.
  5. clancol
    clancol
    Sep 6, 2003
    988
    Middlesbrough
    +6
    Well ill be
    it kinda worked.
