What the best way to go with this
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rookies, Jan 28, 2003.
  1. Rookies
    Rookies
    Jan 4, 2003
    5,506
    +488
    As you all seen or may know I am been thinking of getting a Sony 905 dvd player and want it to be multiregion but I dont really fancy a hardware mod one I prefer to have one that been done by remote.
    Any ideas who sell them this way. I been looking at techtronics but I believe they are hardware mods
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    Not all DVD's can be made M/R via a remote code. If it is possible to make the 905 multiregion via a remote code then your best bet is to do an internet search for the code.
    I would have thought that hardware mods would not be used if a remote hack was possible. Why would anybody pay for a hardware mod if a code was all that was needed?
    Mark.
  3. Rookies
    Rookies
    Jan 4, 2003
    5,506
    +488
    well i believe there is a remote hack for this dvd player not through the original one. Need a special Remote to do it
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    Try looking on this newsgroup:
    alt.media.dvd.hack.sony
    Mark.
  5. kelvin
    kelvin
    Apr 22, 2002
    1,550
    Down South... (Bournemouth)
    +45
    There is indeed a remote hack for the 905 which can be done via a special service remote that you can effectively hire for about £30 (IIRC) (it only works once then you send it back). Can't remember the name of the company that does it but a search on the forums should bring up something. :)
    There is also a series of remote codes that can be programmed into an Ipaq to make the "NS" range of Sony players MR - they were discussed on here about a week ago but only a few people had any success with them so not a "definite" possibility for you. Again, a search on the forums should bring it up :)
    Hopefully this will be of use to you if you can't find a retailer that specifically doesn't use a hardware mod :)
    Kelvin
  6. kelvin
    kelvin
    Apr 22, 2002
    1,550
    +45
    Just did a quick search for you and you should find all that you need in this thread :)
    The company that provides the upgrade remote control for hire is www.dvdchips.co.uk
    Information about the PDA codes is also in there.
    Kelvin
  7. Rookies
    Rookies
    Jan 4, 2003
    5,506
    +488
    Cheers mate
    Avland say theres are software mod so i dunno what to do
