what the best way to get a cheap extra warranty ?
Discussion in 'Plasma TVs' started by spiider, Jun 22, 2003.
  1. spiider
    spiider
    Jun 22, 2003
    16
    I know that several ppl here have purchased from JL in order to get covered by a 5 year warranty... Is there any other way to get a longer warranty ?
    Is the barclaycard extra warranty year applicable to Plasma screens ?
  2. JefUK
    JefUK
    Mar 31, 2002
    444
    28
    +53
    I have just taken out the extended warranty with Barclaycard for an Hitachi 32PD3000 . I used the on-line form on the Barclaycard website. It took about 3 weeks for them to send the certificate.
    Others have reported that Barclaycard will not accept extended Warranty on Plasmas, but I correctly filled in the form and it was accepted without any query.
    The only problem is that cover is limited to a standard £1500.
  3. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Your other option is the new NEC panel, the VP4 Ask your dealer for a 3 yr warranty package, it's about £150 which seems like a deal to me!
    PS great panel too! Good blacks, sharp, lots of usable inputs.
