Hi all, I was just wondering what is the minimum Temp. & max. humidity the room be kept at, I have a BG 808s. I only use the room a couple of times a week & dont want to damage the pj.
Temperature won't be the problem unless you are an eskimo.
Humidity on older projectors can be a real killer espcially if it has a build up of dust which will absorb moisture and could cause the EHT to jump and take something out.
Barco quote the specs as
Degrees C
0-40 operational
-30 to 65 stored
Humidity
0 to 95% non condensing.
CRT Projectors like to be worked they need their batteries and capacitors charging regularly.
