SixNineFourSixSeven
I've just in the past 2 months had a smart meter installed which is giving constant readings.
This has pushed my dual fuel bill up from £88pm to £118pm.
Looking to try and reduce the electric and gas bills.
SO...
at the moment the ancient programable timer next to the boiler has been turned off and we rely on the thermostat at the top of the stairs to control the heating.
I know this can mean that the house is heated with nobody in but in all honesty due to my shifts there would only be nobody in the house for most of the day about one week every 4 weeks.
The temp on the thermostat is set for 21 (GF sometimes finds this cold).
I've got a Valiant Eco Tech (Housing Agency Property).
There are two dials. One has a tap symbol & one has a rad dial.
What temp should i be setting the tap (should it be just below scalding temp) and what setting should the rads one be set too ??
The house is a 2 bedroom 1930's terraced house (4 connecting houses that the 2nd and 3rd house are separated by a alley but joined at the upper wall)
Jean Valjean
SO...
Jean Valjean
