What teminals do i need?......help
Discussion in 'Plasma TVs Forum' started by Macleanrd, Dec 13, 2004.
  1. Macleanrd
    Macleanrd
    Dec 12, 2004
    244
    +8
    Hi All
    Im going to be buying TH42PWD6BX pany in a few days and need some advise before i part with my money.
    I have sky plus and also a pany home theatre system, sky is connected through a scart 21pin to av1 on my present tv, my home theatre is through scart as well and goes to av2 on my tele. I only have a scart connection on the home theatre and as far as i can tell on sky too. Can i have this set up on the pany pw6? Do I need anything extra? or is there a better way?
    Please help
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's perfectly possible to use 2 scart boards, though you could also consider 1 scart and 1 JS VGA converter, and a VGA cable. This enables you to use the VGA port for 1 of your RGB scart sources. It does give a slightly better picture than scart, though going to the expense of 2 of them in addition to an extra PC input might be going a bit far. In the end, you will end up upgrading the HT system, then you will have to re-jig the connections. The JS box and the scart board both have 2nd hand value, so that bit at least should not cause vast expense.
