What Telephoto lenses can be used on a Panasonic FZ5?
Hi i am looking to buy a Telephoto lense for my FZ5 i have only seen them for sale on Ebay with a 2.0x telephoto for £19 and a 3.2x telephoto for £49.99 but was wondering if there are even more powerful ones avaliable and where to buy them from.
Thanks in advance.
M
midtones
You can use various teleconverters, do a search for FZ5 in this forum it should throw back a post with a website that did a bunch of tests.
Can't remember the URL off the top of my head.
K.
Pirate!!
GateCrasher said:
Thanks in advance.
If like the FZ3 the lens thread size is 55mm, look for either the Olympus TCON 1.7 or 1.4. If not, you will require a step ring. These teleconverters are meant to be top notch. Do a Google search or check out eBay. Prices are circa £65.00 for the 1.7 and should ve cheaper for the 1.4.
