V
Vincey
I am not really in to all the AV lingo and techno detail and I am therefore totally lost. :-(
I have come down to a choice between four TV's and I cannot choose between them.
Could you point me in the right direction I'll give you a little more detail
I do not subscribe to Sky I have a Humax Freeview box which delivers a reasonable digital picture 68% signal strength so the box says.
The room this system is going into is 18 ft long by 12' wide and we would be sitting 8 -10 feet away.
DVD recorder Sony RDR-HXD910 with either
(Still not sure on LCD or Plasma )
Pioneer PDP436XDE or
Toshiba 42WLT58 or
FUJITSU P42HTS40GS or a ( this model has dropped in price recently and seems a lot cheaper than you have suggested reviews, seems a good buy) or
Sony KDLV40A12U 40" LCD TV
These are all priced around £2000 tag
Which set up would you go for and why please?
.and can you recommend a sound system to compliment max £600
Many thanks for your anticipated comments
Regards
Vince
Toshiba 42WLT58 or
Regards
Vince
