What surrounds with my 805s ?
Discussion in 'Home Cinema Speakers' started by jont, Aug 8, 2004.
  1. jont
    jont
    Apr 8, 2002
    3,917
    near Aylesbury
    +412
    Am moving house in a couple of mnonths and have the opportunity to use the dining room as a home cinema room (there is a breakfast room that will accomodate our dining table & chairs) ... at last I'll be able to turn up the P7 with the 805's and HTM2 :)
    My question is what would be good surround speakers to complement the 805s ... as there'll be little spare cash for thing I won't be able to get some matching 800 series for a few years :-(
    Was thinking of some 601s or similar which can probably be had quite cheaply ?? any other thoughts folks ?
    cheers
    Jon
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    A freind of mine has 805's with 600s3 surrounds and likes it.
  3. jont
    jont
    Apr 8, 2002
    3,917
    near Aylesbury
    +412
    was also looking at the ds6 surrounds ... but getting a little confused ... if i have 5.1 i guess they go at the rear and are switched to di or bi pole ? ... if i use the full 7.1 from the amp I get two more for the sides ... but what are they switched to ?
    Jon
