What sub ??
Discussion in 'Subwoofers' started by jameson_uk, Feb 15, 2005.
  1. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    I have some oldish (7 years) Kef Q35 Fronts, Q70 reas and Q95C centre setup through a Denon AV2803 receiver. The only source now driving my system is my HTPC machine connected via a digitial connection and I use it for Music, TV and DVD.
    bearing in mind setup and the fact that I use the machine as much for music as film, what sub would you recommend ??
  2. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    What is your budget here?
    Do you have any size restrictions or colour finnish preferences?
  3. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    Yes and No. I do not really want to spend any more than I need to :) and was looking to spend £500 or less. I would like a nice wood finish (light colour) but that is a secondary consideration.
    The most important thing I would say is a sub that will fit in with my system at about the same level and will be good for both music and films.
  4. cR4cKF0x 5TevE
    cR4cKF0x 5TevE
    Sep 7, 2004
    2,035
    St Merryn
    +291
    I'm running a BK XLS200 with my Kef Q35s, Q95c and Q15s as rears. Sub sounds fantastic, integrates really well, and looks great in the light oak finish which blends wonderfully with my laminate floor. The only thing I would say is that if you use the downward firer on a laminate floor, mine sounds immeasurably better now that I have placed it on 2" thick piece of marble with the same 'footprint' as the sub.
    As a bonus, at circa £280 it comes in well under your budget as well!!
  5. PJTX100
    PJTX100
    Dec 21, 2004
    8,129
    +562
    For the money, the BK XLS200 is fantastic. Works very well for both music and film...PJ
  6. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    I would have to agree with the above statements. If you have room for a bigger sub the Velodyne cht10 that is for sale in the sub forums special offer is well worth looking at to.
  7. Kazman
    Kazman
    Jan 14, 2004
    5,264
    Luton, Bedfordshire
    +136
    The BK XLS200 is very good for the money.
    At £500 there aren't many subs that can be recommended. The few that are good include the Mordaunt Short MS909 and the Velodyne CHT 10R. £500 would by a LOT of subwoofer in the classifieds :) Personally, I think I would put a wanted Ad in the classifieds and see what turns up :).
  8. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    If you can stretch your budget a littl, £550 will get you 2 XLS200 which are incredibly good as the pair if you stack them. They come with all the cables you need so you can save a bit there if you need to. :)
  9. Kazman
    Kazman
    Jan 14, 2004
    5,264
    Luton, Bedfordshire
    +136
    Indeed, 2 BK XLS200's would rock!
  10. bob1
    bob1
    Nov 7, 2002
    4,313
    Sheffield
    +128
    I would put them side by side rather than stack them then. :D
  11. Diamond
    Diamond
    I guess we are not allowed to recommend our own brand..? :devil:
  12. Philly112
    Philly112
    Oct 17, 2003
    4,182
    Frodsham
    +1,478
    Why not put an add in the classifieds for a S/H Rel Storm 3. Should be able to get one for £450 or even less. Nice wood finishes available, and excellent for music, OK for movies too (I've had one they seem to fit your requirements 100%). Also they have both high and low level inputs which makes them a bit more flexible than most.
    Phil
  13. Dfour
    Dfour
    Jan 19, 2004
    3,998
    71
    Bracknell
    +85
    Or keep an eye on fleabay.
