What Sub To get
Discussion in 'Subwoofers' started by dalsal, Feb 27, 2014.
  1. dalsal
    dalsal
    Jan 25, 2014
    25
    Hi All
    I have just brought some monitor audio silver speakers with a arcam amp now I am looking for a sub to go with the set up. This is my first set up so would really like some help or recommendations, I am a complete novice so any help would be welcome. I would not mind buying a second hand sub.
    Many Thanks
    Dalsal
  2. l34052
    l34052
    Jul 24, 2005
    1,361
    Silence, i kill you!!
    +189
    I have the silver rx range and use a bk monolith sub with them, the sound is super clean and tight and it integrates perfectly with them, im very happy with the sound.
  3. nikophonics
    nikophonics
    Dec 12, 2010
    124
    Northampton
    +4
    Hi Dalsal
    Welcome to the forum. It would help if you mentioned the arcam model and also the monitor audio model you are using.Are you looking at surround sound or integrating your intended sub into a stereo only configuration? What is your maximum budget for this purchase? Am sure you will receive many recommendations from the knowledgeable folk on this forum.
  4. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,355
    +4,211
    Yes, we can't possibly make recommendations until we know you budget?
    And it would very helpful to know the specific models of the speakers and amp.
    That said, the BK Electronic Subs offer great value, and are used by many members of the forum -
    Sub Woofers - Sub Bass - Subwoofer
    Consider the size of the room, and you budget and simply pick the model that best suits you. The XLS200 and XXLS400 are available in Front Firing and Down Firing. The XLS200 has a 10" bass driver capable of going down very deep. The XXLS400 has a 12" bass driver. Other possible models would be based on available budget.
    If you have a substantial budget then REL, SVS, HSU, Velodyne, etc....
    Steve/bluewizard
  5. kungfuman
    kungfuman
    Jan 14, 2012
    685
    43
    +130
  6. dalsal
    dalsal
    Jan 25, 2014
    25
    Hi Nikophonics
    Thank you for the reply.
    The arcam amp is a AVR300 and the speakers are monitor audio silver Fxi 4373 ( I think that is the model number as I said complete I am a novice at this so please excuse me if I am wrong).
    Budget wise I was looking to spend £400 to £500 on a sub to go with my surround sound set up.
    Many Thanks
    Dalsal
  7. dalsal
    dalsal
    Jan 25, 2014
    25
    Hi bluewizard
    Thanks for the reply.
    My budget is £400 to £500 for a sub to finish my surround sound off. I have a arcam AVR300 with monitor audio speakers Fxi 4373 ( I think that is the model number as I said complete I am a novice at this so please excuse me if I am wrong).
    Many thanks and thanks for the advice
    Dalsal
  8. dalsal
    dalsal
    Jan 25, 2014
    25
  9. dalsal
    dalsal
    Jan 25, 2014
    25
  10. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,355
    +4,211
    In that price range, BK Electronics are probably your best choice -
    On the lower end the XLS-200 (down firing or front firing) has a 10" bass driver and deep response. The XXLS-400 (DF or FF) is very similar but with a 12" bass driver. I think both are compact sealed cabinets.
    The variations of the Monolith are ported and in larger cabinets. Which you choose is completely up to you.
    Steve/bluewizard
  11. nikophonics
    nikophonics
    Dec 12, 2010
    124
    Northampton
    +4
    Hi Dalsal
    Have a read of the XXLS400 review blue wizard sent in his link. You mentioned a budget of £400 to£500, this sub is a no brainer! I prefer sealed enclosures, this sub is such a beast.Cant go wrong for this kind of money. Brilliant sub. You wont be able to audition it as they deal only online. But no need to in my opinion, just buy it!
  12. nikophonics
    nikophonics
    Dec 12, 2010
    124
    Northampton
    +4
    Oh, and theres a thread on here that follows the XXLS400. In the speaker sub forum on subs!(Excuse the pun) Lots to be getting on with then eh.
  13. Sessen Ryu
    Sessen Ryu
    May 15, 2002
    1,051
    Surrey
    +85
  14. dalsal
    dalsal
    Jan 25, 2014
    25
    Hi Bluewizard
    Many thanks for all your input will let you know what one I go for.
    Dalsal
  15. dalsal
    dalsal
    Jan 25, 2014
    25
    Hi nikophonics
    Many thanks for all your help and information will keep you posted on what sub I finally purchase.
    Dalsal
  16. nikophonics
    nikophonics
    Dec 12, 2010
    124
    Northampton
    +4
    You are more than welcome, good luck with the hunt dalsal.
  17. pops107
    pops107
    Apr 4, 2007
    1,679
    63
    hull/ east yorkshire
    +216
    I would have to agree with the bk xxls400df, got one and love it, in that price braket I borrowed 3 diffrent ones before taking the plunge and getting the xxls400df taking members advise of here and they where so right.
  18. dalsal
    dalsal
    Jan 25, 2014
    25
    pops107
    Many thanks for the reply.
    Looks like I am going to take the plunge and get one.
    Dalsal
  19. pops107
    pops107
    Apr 4, 2007
    1,679
    63
    +216
    It's definitely worth a look I the classified section seen some bargains on there, there has been a uprated mono on there for good money if your have the space for the beast, but seen also some xxls400's on there to
