What sub should i take ? please help!
Discussion in 'Subwoofers' started by petarst, Jan 13, 2005.
  1. petarst
    petarst
    Finnaly i have finished with my hi-fi system, and the only thing that i have missed is the subwoofer.
    I have Monitor Audio silver line S8,S1,SCLR, NAD T773 and pioneer 565 dvd, cd nad 542.
    I am wondering which sub should i take :
    Mission m5as or B&W 600 , Wharf. SW150 (what hi-fi winner)?
    They are in the same price range around 600 euros ecept SW150.
    I don't have a more money to put on it.
    Also here where I live there is no distributor for REL or Quad....
    I am very interesting to listen music in dvd-a or sacd format across that sub also. Movies are also important ,but not so much.
    I need advice from you especially from experiance corner!
    thx to all who reply to me...
  2. petarst
    petarst
    no body want's to reply....... :lease:
  3. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,077
    notts.
    +63
    How big is the room that your system is in.
    Cheers Gonzo.
  4. petarst
    petarst
    HI Gonzo thx for reply,
    5x4 meters is the room.
  5. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,077
    notts.
    +63
    If i had to choose between the three it would be the mission m5as but it does need plenty of space to work at its best,I did own one for a short time but it wasnt suitable for my room.
    Cheers Gonzo.
  6. petarst
    petarst
    Hi Gonzo,
    is your room bigger than mine or .....
    is it so difficult to setup it....
    maybe yamaha or....
    cheers,
    Petar
  7. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,077
    notts.
    +63
    My room is slightly bigger than yours.The mrs wouldnt let me put it at the front of the room as she said it resembled a tumble dryer,saying that though my svs resembles a dustbin but she doesnt seem to mind that :laugh: the place were i did put it was too enclosed and seemed to make it boomy so if you have a space that gives it some room you should be ok.
    Cheers Gonzo.
    Ps i did try it at the front and it did sound alot better but as ive said it wasnt to be also it has quite a big footprint.
