What step down converter to use with a US Receiver?
Discussion in 'AV Receivers & Amplifiers' started by Tyler Durden, May 5, 2005.
  1. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,082
    Shrewsbury, UK
    +265
    I am considering buying a Pioneer VSX1015TXK from the states and would like some advice on what I would need to use it in the UK. Thanks
  2. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
  3. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,082
    Shrewsbury, UK
    +265
    I have downloaded the manual and it gives the power consumption the following results: 480W, 630VA so it looks like I will need quite a large one!
  4. Mark Grant
    Mark Grant
    Oct 27, 2000
    1,357
    63
    East Yorkshire, England
    +171
    How about a power tool transformer such as this:
    http://www.axminster.co.uk/product.asp?pf_id=23256&sfile=1&jump=0
    Widely used with projectors from USA that dont have universal PSU, not sure about a receiver though.
    Dont forget that Engish mains is 50 hz, USA is 60 hz, that might make a difference depending on the PSU in the receiver.
    Good luck,
    Mark.
  5. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,082
    Shrewsbury, UK
    +265
    I wonder if it is possible to change the PSU in the machine? I have sent the technical department of Pioneer an email asking them if they can help. I have told them I bought the receiver in the states and have recenty moved to the UK.
