What speed DVD's ????
Discussion in 'Blu-ray & DVD Players & Recorders' started by bailda, Dec 18, 2004.
  1. bailda
    bailda
    Nov 26, 2004
    94
    Stevenage
    Does anyone know what speed media should be used on a Sony GX300
  2. bailda
    bailda
    Nov 26, 2004
    94
    Stevenage
    Or any DVD recorders will help as I am about to order a bulk pack and not sure whether it should be 4, 8, 16 speed DVD's or does it not matter.
    Thanks in advance
  3. dmjohnson123
    dmjohnson123
    Nov 25, 2002
    265
    Wetherby near Leeds
    +5
    I use 4x -R and -RW on my Pioneer 220s which work fine.
    When your recording on a Recorder (unless it has a hard disk) your recording at 1x anyway so you won't see any difference between 4x or 2x.
    You could maybe use 8x, I'm not sure but certainly 4x will be fine.
    The advantage with using 4x rather than 2x is if you get a DVR Rom drive for your PC you can use the discs you've purchased for burning on your PC at 4x rather than 2x.
  4. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    i still got quite a few x4 DVD left (which worked fine), but you should now be able to buy x8 (more suitable) for very similar price (i actually bought some x8 cheaper than x4)
  5. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Have you checked the manual for recommended makes / speeds? Pioneer have a list of makes tested at 8x write for high speed copying at time of publication.
    Also there is a difference in spec between releases of DVD-R and DVD-RW which affects write speeds.
  6. bailda
    bailda
    Nov 26, 2004
    94
    Stevenage
    Thanks people
