What speed broadband for XBox LIVE! ???
Discussion in 'Networking & NAS' started by Sessen Ryu, May 6, 2004.
  1. Sessen Ryu
    Sessen Ryu
    May 15, 2002
    1,040
    Surrey
    +82
    erm... - well, that's it really. Will I notice a difference between 512, 1meg or 2meg ?
    Cheers for any help.
  2. colesy
    colesy
    Dec 28, 2001
    729
    +16
    Download speed isn't important. It depends on what your upload speed is.
    For example I used to be on NTL 1 meg and had 256 upload, which is fine.
    I have friends who are on ADSL 512k and have 256 upload.
    If you have 256 upload then depending on the actual speed of your ISP, then you should be able to host many games on Xbox live without a problem.
  3. Sessen Ryu
    Sessen Ryu
    May 15, 2002
    1,040
    Surrey
    +82
    Discovered this statement from BT:
    From BT:
    Question
    Why is the upload speed of BT Broadband quoted as a range (64-256kbps)?
    Answer
    The upstream capacity of BT Broadband is dependent on the distance from your premises to the telephone exchange. The closer you are, the higher the upstream capacity within the range 64-256kbps. As with downstream speed, your upstream speed will vary depending on how busy the BT Broadband network and the Internet are.
    So in theory I could have 64kbps upload and 64kbps download!!?
    Now I know why they say "Up to 10 times faster than ordinary dial-up." !!!
  4. mrmcdean
    mrmcdean
    Jun 25, 2003
    733
    +27
    We had a BT engineer in our office a couple of weeks ago and I asked him if distance from the exchange made a difference he said it didnt ???? :confused:
