What speakers?
Discussion in 'Home Cinema Speakers' started by Kutz, Feb 1, 2003.
  1. Kutz
    Kutz
    I've got a Yamaha RX-v530RDS amp, and I've been using my brothers KEF 2005 package. Now i've got to give them back I don't know what to get.
    I've listened to Misson M73i, with m7ds as rears and a m7c2 centre. I thought these sounded better than the Kefs, and for under £400.
    I've got a budget of a round £450, and will probably get a sub later. Any other speaker recomendations? Also, I'm not sure what cables I should get?
  2. Mitch2000
    Mitch2000
    Dec 28, 2001
    158
    16
    Kent
    What about Wharfedale Diamond 8's. I demoed these against the old Mission M73 and thought they sounded better.
  3. Kutz
    Kutz
    I'll try does. Any others?
  4. SanPedro
    SanPedro
    Jan 11, 2001
    4,528
    +511
    You could try some of the Eltax speaker packages from Richer Sounds. Not the small sub/sat systems perhaps but try their floorstander combos. They've had some cracking reviews lately and some of the systems have a built in Subs into the base of the front towers and obviate the need for a separate sub.
    They're nicely finished (biwired) and seem pretty well made - well up to the standards of the Missions.
    I bought a set about 3 years ago and am more than pleased with them
    regards
    chris
