What speakers
Discussion in 'Home Cinema Speakers' started by starwarsfan, Jun 11, 2002.
  1. starwarsfan
    starwarsfan
    I have decided to purchase denons avc a11sr amp and need to buy a speaker package sutable for less than 2k, at the moment I am thinking of the b&w 600 s3 set ( for 7.1) and an rel sub. Any other suggestions would be appreciated.
  2. planbeta
    planbeta
    May 20, 2002
    16
    Stourbridge
    You might want to look at the KEF Q Series and also M&K K Series...
    Loads of choice out there really... :blush:
  3. starwarsfan
    starwarsfan
    any other suggestions?
  4. steve1056
    steve1056
    Apr 20, 2002
    384
    Reading
    +5
    Try Dynaudio Audience speakers -- they are brilliant! The 122 model (fronts), the 122C (centre) and 42's (rears) should fit within your budget.
    Not sure that your amp will be able to drive them, but they are certainly worth auditioning IMO.
    Cheers,
    Steve
