What speakers with Denon 3805 for 5.1 KEF/MS/MA?
Discussion in 'Home Cinema Speakers' started by Saya2001, Jul 23, 2004.
  1. Saya2001
    Saya2001
    Jul 20, 2004
    90
    I have finally decided to go for Denon 3805though not sure about speakers; Either Mordaunt-Short THX Avant System
    or Monitor Audio Bronze or KEF Q7 5.1
    My budget is around 2K inc AV
    Many Thanks
  2. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Monitor Audio Silver series, try these :thumbsup:
  3. Breitling
    Breitling
    Jul 15, 2004
    9
    Q7's are a great well balanced speaker
  4. dishdoc
    dishdoc
    Apr 16, 2004
    640
    The Toon ! !
    +23
    Deffo Kef Q7! :thumbsup:
  5. Wannabe-THX
    Wannabe-THX
    Apr 7, 2004
    245
    Depends on the size of the room they are going in.
    But as me being a Kef junkie, then I would say Kef's all the way. ;)
    Fish
  6. mjcairney
    mjcairney
    Oct 26, 2003
    7,143
    2
    2
    137
    Airdrie, Scotland
    +991
    The only way to do it is to listen to them yourself and make up your mind - after all, you'll be the one listening to them, and one man's taste (or ear) is not necessarily the same as the next.
    Go for an audition!!
