What Speakers with AVR 3805
Discussion in 'AV Receivers & Amplifiers' started by tryst, Jul 7, 2005.
  1. tryst
    tryst
    I am planning for a 3805 and i have Tannoy Mercury speakers with me along with a Velodyne VX-10 sub.Is this set gonna work right or shall i think of some other options ? Please advice me on the cableing issue too.I am confused about the interconnects and speaker cables from vandenhul and monster.Which one is better?
    tryst
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I am using lowly Tannoy Mx's with my 3805, and they sound ok to me. The 3805 is a smooth laid back amp compared to my old Sony. That combination tended to sound a little harsh at high volumes. The upgrade has shown the amp to be the reason not my speakers.
  3. tryst
    tryst
    Thanks for your advice.How do you recommend Klipsch or B&W 6 series as a combination with 3805.
    tryst
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I can't! Never heard either combination though the B&W's should be a configuration common enough to to find other users. In all honesty, unless you have unlimited resouces to buy and try two or three, I would get your amp and use your existing speakers. Take a little time to choose their replacements by auditioning. You should have no problems finding a decent retailer who will help you out. In the end what I like might not sound too clever to you!
    p.s. My speakers were the ones placed below the Mercury's before Tannoy combined the two.
  5. frustin
    frustin
    Jan 18, 2005
    74
    Braintree
    i had the tannoy MX series for mine, i now have the Kef KHT6000's and my god is there a difference! (in price as well :) )
  6. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    I use three Kef KHT9000ACE's for the fronts and two Kef KHT5005's for the rears due to limited space, and cash, and they sound and look fantastic IMHO.
    Cheers, Lee
  7. White_Nemesis
    White_Nemesis
    I use the set-up shown below and am very pleased with the sound :thumbsup:
    I auditioned a number of sub / sat combos but there is no substitute for good sized floor standers up front. The Aelite 3 go deep and handle all the serious music listening, the sub is for movies and certainly shakes the furniture (without boomimg!) :D
    But everyone is different and each room adds something to the overall effect, so the best advise alway is, find a good retailer and get some speaker combos in and just listen!
  8. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Also make sure your crossover settings are all in place to make sure you arn't missing any sound.
    I think the KHT KEFs only go down to around 120-150. So whant to make sure the sub is set to cover the rest.
  9. frustin
    frustin
    Jan 18, 2005
    74
    Braintree
    if you are using the kht6000 with the "bass extender" stands, then the range is supposed to be 75Hz - 30kHz.
    I set my cross-over to 80hz and everything sounds good.
  10. rmask
    rmask
    Mar 25, 2005
    115
    +4
    triangle esprit series, if you dont mind the price:)
  11. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Hang on your aren't actually changing the speaker itsalf, the stand is just picking up weak low frequencies and making them more noticabile.
    The speaker still has the same frequency range as before. The stand just helps with the frequncies it can't deliver.
  12. frustin
    frustin
    Jan 18, 2005
    74
    Braintree
    yes, so if it helps with the frequencies it cant deliver, therefore making them delivered, theres no point in getting the sub to take them on.
    besides which; i wasnt disputing that. i was just copying and pasting what it said in the spec.
  13. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Well thats a big risk. You could damge the amp or speakers by trying to feed a signal that they can't really handle themselves.
  14. frustin
    frustin
    Jan 18, 2005
    74
    Braintree
    i dont understand. By setting the crossover to 80hz and the spec says they will go down to 75hz, were is the risk? Granted, if i set the crossover to the next notch down I'd be inclinde to agree but not when the spec says they'll go that low.
