What Speakers should I get?
Discussion in 'AV Receivers & Amplifiers' started by Killer, Aug 20, 2001.
  1. Killer
    Killer
    I am looking for a S.Sound speakers, I am hoping to have my front 2 as the long standing ones...
    What make should I go for?..My budget is £1000 and I need to use this for Home Cinema as well as Audio, (Mostly home cinema though)
    Thanx
  2. johna
    johna
    Dec 15, 2000
    880
    Kent
    +9
    B&W Series 2 aren't bad.
  3. Guest
    What is the rest of you're speakers and you're sound system made up from ?
  4. Killer
    Killer
    Well thats the thing, I am staring from scratch and i wanna know what i should go for....
  5. Lowrider
    Lowrider
    Buy an Energy SL8.2 subwoofer or better
    If you like KEF: 4 Q15.2 + 1 model 100
    If you like B&W: 4 DM602 S2 + 1 CC6 S2
    Or the equivalent in other brand you like, make sure the center speaker is as good as the others, buy the best subwoofer you can afford, and then you wont need large speakers in front.
  6. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I'd suggest you have a listen to the rega surround stuff. Jura front's etc.
