What speakers for Sony DG820
Discussion in 'Home Cinema Speakers' started by Tautitan, Feb 12, 2009.
  1. Tautitan
    Tautitan
    Nov 28, 2007
    108
    Great Yarmouth
    +4
    I'm looking for a set of surround speakers for the Sony DG820, preferably under £200, preferably better than or similar to the ones with the Sony DAV-SR1 lol. Too much?
    Also, I'm getting SkyHD soon and was told by a friend that only the movie channels and a couple of others actually broadcast 5.1 sound, is this true?
    Matt
  2. micks_address
    micks_address
    Nov 29, 2001
    4,671
    83
    Dublin
    +239
    i have the sony dg920, and run the mordaunt short premiere plus system with it.. 309i sub.. is very good... might be slightly over budget but as its an older system you might be able to get a good deal on it
  3. Scott_Mac
    Scott_Mac
    Jul 4, 2005
    6,168
    2
    2
    Bromsgrove
    +651
    Your friend doesn't lie on the audio from Sky HD.... bit naff really!
    As for speakers under £200, the usual suspects are:
    Jamo A102HCS5 5.1 Home Cinema Speaker Package 500W: Amazon.co.uk: Electronics & Photo
    Mordaunt Short Avant Premiere
    Sub is a bit naff in both to be honest.... the 309i is available in the better MS ones but bumps up the price significantly!!!
  4. Tautitan
    Tautitan
    Nov 28, 2007
    108
    Great Yarmouth
    +4
    I have found the Wharfedale Vardus system for around £330, is that any cop and is it compatible with the amp? Anything else around this price range and does anyone know how the speakers with the DAV-SR1 stack up?
    Any word on how to get 5.1 out of Sky? For instance, if I am watching Lost or something like that, can I get it in 5.1?
  5. Tautitan
    Tautitan
    Nov 28, 2007
    108
    Great Yarmouth
    +4
    OK change of question lol.
    I have an Xbox360, PC and soon to be SkyHD which I would like to connect to a projector through only one HDMI cable. Are there any Blu-Ray packages out there with HDMI pass through which I could then use a HDMI switcherooney box on to get the 3 inputs?
    EDIT: Or even http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/4641 Am I correct in assuming that the HDMI signal input will strip out the audio to pipe through the included speakers and pass the video signal onto the projector?
  6. Drus
    Drus
    Aug 13, 2006
    4
    you say you have the sony dg820 so why would you need another unit with hdmi pass through when the sony does that?
  7. Tautitan
    Tautitan
    Nov 28, 2007
    108
    Great Yarmouth
    +4
    Thanks for the reply, although I don't think I mentioned I had it already, just that I was looking for some speakers to match it, sorry if i gave the wrong impression there.
