what speaker size?
Discussion in 'Home Cinema Speakers' started by adox, Jan 6, 2003.
  1. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    i have recently added a subwoofer to my system and am currently playing around with different settings to get the best sound. i am unsure what size to set the speakers to for best results for my needs. i use the setup 50/50 for hc and music. any advice would be greatly appreciated.
    marantz sr4300
    pioneer dv350
    mission m73 fronts
    mission 77c1 centre
    mission m70 rears
    veldyne cht-10 sub
  2. juboy
    juboy
    With a sub as good a yours, it would normally be best to set ALL of your speakers to 'small' and set your amp's crossover to 80hz.
    Then set your sub up to direct mode, crossover to max and tune the sub's volume control and phase from there.
    This allows the sub to grunt out the LF stuff and should help the Missions do their job with a little more ease.
  3. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    thanks for the advice juboy. is that setup suitable for music as well?
    thanks again.
  4. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Agree with Juboy - small all round - you should find it sounds better that way - of course you can try it with the main speakers set to large and then small and see which you prefer.
    You should find that your system sounds better (for music and movies) with the mains set to small because both your amp and your main speakers aren't trying to produce anything much below 80Hz.
    I did this very experiment with some classy KEF Reference floorstanders (£1750) and they were being driven by a big THX power amp - even they sounded better (for music and movies) when set to "small" with an 80Hz crossover - that surprised me because those KEFs can drop pretty low.
    The bottom line, IMO, is - if you have a decent sub (which you have) then let it take care of the low frequencies and let your other speakers concentrate on just the >80Hz stuff.
    Matt.
  5. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    thanks matt.
  6. Reano
    Reano
    Jan 6, 2003
    873
    28
    Telford, UK
    +47
    Wow that is what I'm going to try tonight! I have the CHT 12 Kef Q55 up front and Kef Cresta at rears. I set the Q55 to large and the cresta's to small. One the pioneer Amp vsx909 you can set the subwoofer to plus which sends the lower bass frequencies to the woofer rather than the front. One more thing I have found that works is if you set the subwoofer channel on your amp to have more db gain over the others it means you have very good control of the bass just by using the volume control on your velodyne. E.g. I have turned the gain to 5db above the rest and my Velodyne sounds sweet even at just 25% of the volume.
  7. adox
    adox
    Nov 5, 2002
    688
    19
    dublin
    i have my velodyne at no more than 10% and find it about right.
  8. juboy
    juboy
    I must admit I was surprised to see someone running +5db from the amp and using the sub at 25% volume... my amp is set to output 0db and the Velodyne never gets much passed 15% even when listening to films at near reference levels.
  9. Reano
    Reano
    Jan 6, 2003
    873
    28
    Telford, UK
    +47
    Detached house with windows open :D but maybe I think it is about 15% just a guestimate!!
  10. buns
    buns
    Apr 29, 2001
    6,066
    58
    Belfast
    Im afraid my ears disagree..... maybe its my amps fault, but i find the soundstage lacking when all set to small. So fiddling is a good idea!
    ad
  11. jim.rae
    jim.rae
    What's important is to let the sub do the bass work without interference from the rest of the kit.
    That's why people set the stereo speakers to 'small' to cut the bass reponse from them which can really confuse the sound stage.
    The sub should be giving you a 'feel' of bass rather than window rattling sound in my view - a sub really can give subtle effects when performing well...
    I have three subs in different rooms around my office/house and they are so much better than traditional 'big' speakers.
  12. Reano
    Reano
    Jan 6, 2003
    873
    28
    Telford, UK
    +47
    I have just come back from setting all my speakers to small with the sub (CHT-12) handling all the bass.
    My set up is kef q55 as fronts and kef cresta's as rears with the Velodyne.
    I noitced that the fronts were too bright IMHO so set back to Large. So current set up is large fronts, small surrounds and subwoofer on 'plus' setting (which still handles most bass).
