what speaker setup for 6.1 EX/ES
Discussion in 'Home Cinema Speakers' started by djewson, Jul 26, 2002.
  1. djewson
    djewson
    Hi all, just looking for a bit of info from all you professional home cinema experts out there.
    I am currently awaiting delivery of my new Pioneer VSX-811 AV amp, which is DD/DTS, EX/ES compatible and would like a bit of help with selecting some speakers.
    I already have a Yamaha Sub.
    What is the best way to go, -
    All 6 speakers the same model (ie.3 pairs identical to retain timbre throughout)
    Buy a 5 speaker package, but what is the best to use for the rear center, do I get 1 to match the L/R rears or another center to match the front.
    This is doing my head in at the moment as I am being told different things by different stores etc.
    My friend has a Mission speaker pack for his 5.1 and all his speakers are identical.
    However Richer sounds told me to go with the 5 pack and put another center at the back as all matching speakers would sound crap.
    But then again this guy told me I would need a new DVD player to get 6.1 anyway, one with a 6.1 output and he didn't even know of any on the market so he wouldn't bother with EX/ES anyway.
    I currently have a Pioneer DV-444, which serves me fine as its only about 3 months old.
    Can anyone offer any advise on these matters please
    Dean
    :confused:
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,497
    Matching speakers all round is a very good way to go as they will all match tonally. This means the sound won´t change as it moves from speaker to speaker.
    Ignore what you´ve been told by RS as quite frankly they are talking crap. You also do not need a new dvd player to get 6.1, the amp will be doing the decoding, so your Pioneer is absolutely fine.
    If it were my money I would buy 3 pairs of matching speakers and use them. What sort of budget do you have? We can then give you some ideas of what speakers to look at.:)
  3. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    693
    London, UK.
    +38
    > anyway. I currently have a Pioneer DV-444, which serves me
    This guy should be shot and not allowed to give advice or work in an hifi shop! If your amp has 6.1 EX/ES decoder, then you don't need to change your DVD player.
    Your DVD player will output the audio as raw digita data via the optical/coaxial output, it doesn't care about how many channels it is, it's up to your amp to pick up the digital data and deal with it.
    I too have the Pioneer 444 player, which is hooked up to a Denon 2802 amp with 6.1, and 6.1 films come out great! :)
  4. djewson
    djewson
    thanks for the quick responses guys,
    Not sure about the budget, Not too expensive, £350 max maybe.
    I'm appalled at the advise given to me by Richer sounds, what a muppet.
    However they are very cheap for Speakers.:blush:
    I was looking at maybe 3 pairs of mission 700's, they are doing them for £80 off at the moment, making them £50 per pair.
    What HIFI gave them 5* rating, how will they perform as AV speakers though ??
    The shielding isn't an issue as I have a 52" Rear projection TV.
    Any more advise though would be much appreciated.
    Dean
  5. john87
    john87
    The Mission 700s will work well in a home cinema setup.
    If you want deep bass, buy a subwoofer, one of the Paradigms from RS will do well.
    You could have... 6 X Mission 700s (£150) and Paradigm PS1000 (£150 with What Hifi mag.) Total £300 with £50 to spend on cable.
    You will also need to spend another £100 or so on stands.
  6. djewson
    djewson
    I already have a Yamaha YST-SW60 for my sub,
    That should be powerful enough, yes?
    So it looks like the Missions are the way to go,
    £150 plus Stands, woo hoo.
    I already have some good quality cable down so, not too bad really.
    Dean
  7. john87
    john87
    Should be a good system, possibly the best value for money out there :)
    About the sub, I don' t know, I've never heard it.
  8. djewson
    djewson
  9. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Dean
    this is the biggest pile of do do I have heard in a while. It is the best way forward for sound but isn't always easy to fit arounf tvs etc.
  10. john87
    john87
    Well, it will be better than nothing but get saving for one of the Paradigms, or another sub reccommended around here :)
    50W is not a lot of power for a subwoofer and at first glance the frequency range looks impressive... down to 21Hz... until you realise that is at -10dB :rolleyes:
