what speaker package is best ?
Discussion in 'Home Cinema Speakers' started by dean richardson, May 23, 2001.
  1. dean richardson
    dean richardson
    i want to get dts (5.1) sound and have a choice of speaker packages to go with my dts amp.
    Any preferences or stories on any of these ?
    Denon SC AVF 100 5.1
    Quadral Surround 1240 active
    Videologic Digitheatre DTS
    Mission system 6 pack
    thanks for any help !
  2. spider
    spider
    deano
    i dont know about any of the above but if you want a good entry level package you could do no better than the Tannoy MX range. I have the M3 frts,M1 rrs and the Mc centre and they are good. I've heard the Mx range is even better at around £450 for the lot, go and audition them for yourself you won't be dissapointed. Well good hunting hope this helps.
    spider. :)
  3. Force Field
    Force Field
    Deano
    I have the Mission 6 pack and am well pleased with the output. This is my first speaker package so I have nothing else to compare it with, but valuewise it takes some beating. :)
