What Speaker Package for £200 ???
Discussion in 'Home Cinema Speakers' started by lewisn1, Sep 3, 2004.
  1. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    I have a pioneer amp and am getting the pioneer 575a dvd player soon.
    What I need now are some speakers but I only have about £200 spare.
    I have seen the tannoy fx5.1. They seem ok, any ideas on what to get?
  2. lewisn1
    lewisn1
    Dec 23, 2003
    57
    Wales
    Anyone ?? I really have no idea what to get!!!
    Is the Sony SPSL2 from richer sounds any good?
  3. ][Uzzy][
    ][Uzzy][
    Aug 30, 2004
    94
    Yeah i would like to know this too, as i've been also looking at this speaker package from richersounds.co.uk. I've tried finding info on this but info is very scarce.
  4. Fordy
    Fordy
    Jul 9, 2003
    1,537
    41
    Liverpool
    +24
    I can only advise from experience, so here goes.
    Go to http://www.pricerunner.co.uk and have a look round there. There's tons of speaker packs for £200 and under, just try and get one with a subwoofer. But to be honest dont expect much for £200. Look at packages from brands known for their speaker quality, Mission, Wharfedale, JBL, Tannoy, Elac, Eltax, Sony. Also if it looks too good to be true, it likely will be i.e, a pair of floorstanders + Rears + Centre +Subwoofer is likely to be crap.
    My opinion 2 pairs of mission m71(£60) and matching 7c1 centre (£50)from richer sounds and pick up a cheap active sub from them with whats left, also dont forget cable.
    Hope this helps
  5. MS-Yam
    MS-Yam
    Aug 12, 2004
    240
    16
    Got the perfect option for you mate (if you can stretch to £230!):-
    Go to www.hificonfidential.com. You can pick up the Mordaunt-Short Premiere package now for just £230. I paid £250 for mine and it was the best £250 i'd ever spent. Really good sound quality, build, good looks... great!
    You will notice there are a few different types. If you pay £300, you get a hell of a sub. But the 308 model is excellent value also.
    I have heard that the Tannoy ones are :thumbsdow
    Good luck
