What speaker cables fo you recomend for my system?
tony kop77
Joined
Sep 27, 2002
Messages
6,693
Reaction score
424
Points
1,168
Age
48
Location
Northamptonshire
I have just ordered the Kef 2005.2 speakers along with the Denon 2803 amp for my bedroom which is 12ft by 10ft. What speaker cables do you recomend I buy?
I ordered my system from sevenoakes and I enquired about the QED leads £10 a metre but was told I dont need to spend that much for wuality sound and £5 a metre woulkd just as good.
I wouldn't spend as much as £5 per metre on cabling KEF Eggs. Hifibitz have QED Bronze Special edition at £2.50 per metre here which will be more than adequate
Ian,
How does the QED Bronze compare to the QED Original wire ?
Crazzy, which speaker wire did you get in the end ?
I bought the QED original for £2.75 a metre.
Sorry but I don't know the answer. I only know them by reputation
Thanks Guys.
I am thinking of getting QED Original for the rears (approx 12.5 metres for each of the three i.e. 37.5m) and 3x2m runs of QED Silver Anniversary for the fronts and centre.
Although the rears don't all require 12.5 metres, I seem to remeber that it is best to have the same length of wire to ensure even sound delays.
What do you think with regard to the combination of wires, or should I stick to QED Original all round ?
Unfortunately QED Silver Anniversary all round would be too costly :(
The difference between the bronze and original is:
The Bronze is a copper based version of the silver anniversary so shares conductor sizes, similar jacket and twisting.
So is a step towards the silver at a step towards the price!
I asked the same questions when buying cable for my eggs.
On the "same length" question, I asked about this when buying the eggs. The reply from the guy in the shop was that having equal lengths for the front speakers wasn't as important with the eggs as for more audiohpile-quality stereo speakers. Sure, it wouldn't do any harm, but I probably wouldn't notice any difference.
I think the issue with different lengths is actually more to do with any changes to tone of the sound that is produced rather than the delay. As the signal travels at almost the speed of light, the delay through an extra few metres of cable would be tiny.
As you're just talking about must the rears, it's probably not even worth worrying about, and just going with the lengths you need.
I use three QED SA cables, each between 3m and 5m for the front three eggs, and haven't found any problems.
For the rears, I'm curently using some cheap (50p/m) 79 strand stuff from B&Q. I'm moving house soon, so didn't want to spend a fortune on the long runs to the rear, knowing that they'd be replaced soon. I'm planning to use QED Original for the rears when I rewire them though. The cheap stuff sounds OK on the rears, so it'll be interesting to see if I notice any difference with the QED Original.
Balders.
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
