What Sound Card
Discussion in 'Computer Components' started by jameson_uk, Sep 8, 2005.
  1. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    My HTPC rig is currently plugged into my Denon 2803 receiver via an optical cable from the onboard NForce sound. I was thinking about getting a new soundcard but am not sure what to go for.
    Am I right in thinking that as I am just passing everything out digitally anyway that the new soundblaster x-fi would be no better than an older Audigy ??
    Could I even just get a Soundblaster Live (does this have a coax digital out)???
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,255
    Southsea, UK
    +86
    I use the coax out on my NForce 4 board, having previously used an Audigy 2 ZS. I have noticed no weaknesses from the onboard sound in comparision to the Audigy 2.
    None of the soundblasters have coaxial out on the card but you can use a coax through an RCA to Mini-jack connector.
  3. jameson_uk
    jameson_uk
    Dec 9, 2004
    3,707
    Birmingham
    +579
    For some reason I have always had something against optical connections and preferred coax. I have the problem that the optical socket on my NForce2 mobo is not very secure and the cable wont stay in which is a pain. Not really a biggy but has annoyed me enough to consider a new card :)
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,255
    Southsea, UK
    +86
  5. phunkey_monkeh
    phunkey_monkeh
    I had the Trust card 514dx.
    Complete Rubbish, ive ended up changing it for a HDA digital 7.1.
    The Trust card wouldnt give me 5.1 in MCE, only Windows. I put the HDA in today and 5.1 in MCE instantly.
    It has Optical Out, and Coax out. £58 from overclockers.
  6. typing00
    typing00
    Dec 4, 2002
    101
    Hmm ... it has been a while since I researched it, but if you are into music, you will need a sound card which passes bit perfect digital out. Personally I use the M-audio Audiophile 24/96 with Winamp ASIO plug-in, which is a 70% to 100% improvement on Soundblaster Audigy 2.
    AFAIK, nforce sound card cannot pass bit perfect digital out, but it has been one year since I researched into this.
