what souncard should i get???
Discussion in 'Desktop & Laptop Computers Forum' started by hddvdman, Mar 18, 2005.
  1. hddvdman
    hddvdman
    Feb 11, 2003
    6,206
    somethere over there but not near here, there
    +156
    i have a hp media centre and need a soundcard that can either output via coax or f.optic - what one should i get to get the best dd/dts sound - thanks for your help
  2. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    If you use the SPDIF output of a soundcard you will need to connect that to an off board processor/amp for decoding the DD/DTS material. As long as you knew that it really depends on the quality you require and the rest of your off board kit. Low/mid price performance would be the Soundblaster Audigy2 ZS (platinium etc.), top spec would be the RME HDSP9632.....
  3. hddvdman
    hddvdman
    Feb 11, 2003
    6,206
    +156
    hi
    i want to plug into my pio ax5 via digi coax - yeah someone else recommended what you said too mate
    thanks for your help.
    chris
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    I haven't found a better card than the RME at anything like sensible money, but you have really got to want it at £300+........
  5. hddvdman
    hddvdman
    Feb 11, 2003
    6,206
    +156
    yeah i know 100 really was my limit - thanks for your help mate
