What Sort?????
Discussion in 'Home Cinema Speakers' started by Mikey1, Dec 6, 2000.
  1. Mikey1
    Mikey1
    Right can anybody help me with sort of surround and centre speakers to get? Ideally a package, I have already got a active sub and front speakers but I need the surround and centre ones urgently.
    But alas I only have a maximum of £300, I have been told by some people at work that for that money I should be able to get some descent stuff.
    Many thanks
  2. simonsez
    simonsez
    What make and model are your front speakers? You will probably want to try and stick to a single manufacturer if at all possible. This will help particularly with the center speaker blending in with the existing fronts.
