grahamlthompson
In memoriam
Never really used the slo-mo capability of the camera so set up a test filming a stopwatch. Firstly I don't think it's something you couldnt emulate post prod using any editor capable of frame interpolation.
The camera produces a 11.881sec clip which from looking at the video equates to around 4.5seconds of real time footage (interpolates approx 2.4 times the original frames) to produce 1080i 1440 x 1080 25 fps content.
It didn't record any audio guess it can't handle pitch correction.
Judge for yourself, test clip available here
https://www.adrive.com/public/QPrxMn/00001.MTS
Clip details
Clip details
Code:
General
Complete name : E:\SloMoTest\00001.MTS
Format : BDAV
Format/Info : Blu-ray Video
File size : 14.7 MiB
Duration : 11s 881ms
Overall bit rate mode : Variable
Overall bit rate : 10.4 Mbps
Maximum Overall bit rate : 18.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=13
Codec ID : 27
Duration : 11s 880ms
Bit rate mode : Variable
Bit rate : 9 701 Kbps
Maximum bit rate : 16.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.250
Stream size : 13.7 MiB (93%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 11s 968ms
Bit rate mode : Constant
Bit rate : 256 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : -80ms
Stream size : 374 KiB (2%)
Text
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Duration : 11s 375ms
