What software?
Discussion in 'Home Entertainment Computers' started by Iccz, Feb 9, 2009.
  1. Iccz
    Iccz
    Apr 29, 2008
    24,060
    Keystone City
    +6,750
    Hey folks, basically i've just knocked up a machine to run as a HTPC, and i'm not totally sure what is the best option for me.
    I like the sound and look of Media Portal so i'm going to be giving this a test.
    Basically for now all I want to be doing is playing ISO images and other video files, no Blu-Ray, no TV etc.
    I'd like them to be auto-mounted for playing - not too fussed what they play in as long as they play :p
    And also some Divx files which i'd like to be in a seperate part of media portal (or another piece of software)
    What would you folks suggest?
    Am I right to think Media Portal will do what I need?
    I have Vista 64 bit installed at the moment but could put 32 bit on if that is likely to be better?
    :thumbsup:
  2. surfermc
    surfermc
    Dec 11, 2004
    90
    +11
    Mediaportal will do what you want. You might need to add a few codecs depending on the content you have. Have a look at the Standalone Filters package that has been created. It should play most content.
    To auto mount ISO image you will nedd something like Daemon Tools.
