What software to use
Discussion in 'Blu-ray & DVD Players & Recorders' started by cliff_62, May 1, 2002.
  1. cliff_62
    cliff_62
    Have got a panny DMR E20, recorded some footage off my dv camcorder onto ram disc, but don't seem to have any software that reads vro files. Has any one got any suggestions what to use to edit the vro files on the ram disc.
    thanx
    cliff
  2. ammar
    ammar
    Yes I have a DMR E20, and you can play the VRO file on a PC using any player software, I use Power DVD 3.0 and its fine.
    Ammar
  3. ammar
    ammar
    Hi again,
    forgot about the edit.
    I have used TMpGencthingy to convert VRo files to MPG, no problem. Although I have yet to find a DVd author software that will handle them for recording back to DVD-R. ULeads MyDVD cannot recognise the audio aspect of the file generated by TMPGenC and Nero is having problems with files larger than 4 GB, so still trying various things.
