What size TV to get...
Discussion in 'Televisions' started by glandgraf, Oct 29, 2003.
  1. glandgraf
    glandgraf
    I'm finishing my basement up now and want to start looking at big-screen Tv's. Are there 'guidelines' for buying a big screen in terms of size? My room is going to be about 10'-6" from front to back. What size TV should I be looking for.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    if basement has no pillars forget TV order a PLVZ2 £1200 and fill the wall! add some nice speakers and away you go (PJ cheaper than LCD, Plasma and even rear Projector mate.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,788
    Somewhere in South Yorkshire
    +4,975
    The bigger, the better. And front projection does offer the largest size per pound.
    All screens/tvs etc shrink during use*. Even 9 ft diagonal projection screens.
    * Not really, of course. But you most certainly do become accustomed to the size, which gives you the impression of shrinkage.
  4. irishstu
    irishstu
    read your message, i was looking for a 36 inch tv, couldn`t afford a plasma, then bought the sanyo plvz2 when it just came out. You wouldn`t regret buying it, i paid 1500 and it has fallen to 1200 and still don`t regret it...
  5. Zaichik
    Zaichik
    Mar 5, 2002
    1,164
    +219
    He's right, you know. My 28" TV seemed huge after the 17" I had before, but now I wonder if I shouldn't have got a bigger one! :D
  6. LV426
    LV426
    Jul 14, 2000
    12,788
    +4,975
    Yes, you should have!!
  7. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Don't wish to put a dampener on this "bigger is better" theme, but don't forget that some people notice flicker, line structure etc (even to the point of headaches).
    Glandgraf,
    Why not take a tape measure into your local TV showroom and compare screen sizes from 10ft 6in away?
    Of course, you can't over do it, or they'll send for the men in white coats. :laugh:
  8. LV426
    LV426
    Jul 14, 2000
    12,788
    +4,975
    Not on a high resolution (1280x720 or up) LCD projector. They may see rainbows on a DLP, but no line structure.
  9. mildred
    mildred
    I would go for no more than a 28inch widescreen in that tiny room :D
