What size Screen ???
Discussion in 'Projectors, Screens & Video Processors' started by dan76n, Aug 14, 2005.
  1. dan76n
    dan76n
    May 12, 2003
    88
    australia
    Hi all, I am building a room 5.8 x 3.9 metres (19 x 12.8 feet). what would be the most suited size screen for this. Is there a formula to work out what size screen from the distance you have ???
  2. spamboy
    spamboy
    There are a lot of variables to this, however the way people normally look at this is to start from having a seating position of 1.5 screen widths.
    The variables are:
    Brightness, the bigger the screen, the brighter the pj needs to be - a higher gain screen will help with this if it's not bright enough. If you have any ambient light, you need the on screen brightness to be higher.
    Screen door \ panel structure. As you get closer to the screen you can begin to make out the discrete picture elements, which can be distracting. LCD is generally worse for this than DLP.
    Personal preference; Some people like to have most of their vision filled by the screen, some don't.
    Projector placement \ throw. Depending on where you can put the pj that will limit the screen size options.
    I've just sized up a screen for my hc and the way I did it after spending ages with projection throw calculators, looking at predicted foot lambert brightnesses, reading various people's opinion's etc was to set it up on a stool and zoom \ move it around until I got the biggest picture that still looked good. I reccomend that you do the same.
  3. SimP
    SimP
    Aug 18, 2005
    137
    +3
    If you do a google search on "viewing distance calculator" hopefully the top result will be from a webpage including the word homestead in it (I'd post the link here for you but I don't think I can yet). There's a lot of useful information about SMPTE and THX standards here. It needs 3 pieces of information: How far you sit from the screen (in feet), what shape your screen is and the screen size. If you're uncertain about distances the calculator "will tell you what the optimal seating distances are for the selected screen size." Very handy.
  4. DLau
    DLau
    Aug 11, 2005
    67
  5. MississippiMan
    MississippiMan
    Oct 15, 2004
    235
    +10
    Great post, Lunchmeat! ( :spam:..boy ) JKA!
    Dan76n, Let's keep it really simple
    First off, what PJ are you going to use / consider?
    Take that info to this site:
    http://www.projectorcentral.com/projection-calculator-pro.cfm
    Enter in the PJ's make-model.....
    .........and you'll get your figures in no time.
    Post up again if you want to make your screen. Smaller screens are very easy to accomplish in the "DIY" genre, if such is/can be your 'bag'.
  6. sonofmoth
    sonofmoth
    Nov 30, 2002
    384
