What size screen should i get when i have my sony h50?
Discussion in 'Projectors, Screens & Video Processors' started by activeuk, Oct 20, 2004.
  1. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    my room is 15 foot any ideas i the best size screen i want a 16:9
  2. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    It's pretty much up to you really (within reason).
    It will be dictated, to a large extent, by the placing of the PJ and the available zoom range on the lens, but within those constraints, you get to choose!
    How far away will you be sitting from the screen? (you probably won't want to be sitting closer than about 1.5x the screen size)
    Smaller screen means brighter - but then it's........well, smaller!!! :)
  3. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    would i 100 inch screen be over the top?
  4. NaimBoy
    NaimBoy
    Dec 11, 2003
    98
    Aside from what's physically possible with the zoom range of the projector, there's two things to bear in mind, as far as I can make out (being in the same newbie position as far as projectors go...)
    First there's the image quality/brightness - as MikeK has already mentioned, the smaller the image the brighter it will be and the closer you can sit without seeing any artifacts in the picture.
    The second is viewing fatigue - too big a picture will result in your eyes having to move around a lot more. Think back to the last time you went to the cinema - are you the type of person that likes to sit right at the front or do you prefer to be further back ?
    If it helps, get some low tack masking tape and mark out the screen outline on the wall and then sit back and see what you think. For me, an 80" screen would appear to be plenty big enough from 12' away....
  5. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    100" - well plenty of people use them, but bear in mind Mark's comments and remember that as far as the viewer is concerned, the size of the screen is relative to the distance you sit from it.
    EG, an 8ft screen may seem the same size from 8ft away, as a 12ft screen seems from 12ft, and so on (I'd have to check my maths for the specific figures :) )
  6. Drew C
    Drew C
    Feb 24, 2003
    319
    Leeds
    92" is a popular size mate.
    Good compromise between quality and quantity. :smoke:
  7. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    were is the cheapest place to get a 92" pull down screen?
  8. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    drhscreens.co.uk get my fullest recommendations. They are very helpful and seem very willing to help if you have any questions/problems.
  9. Drew C
    Drew C
    Feb 24, 2003
    319
    Leeds
    Have a look at some of the forums sponsors (nexnix,discounttv etc.) You should be able to get one for around £200.
    I think mine cost about £180 a year ago.(Projecta ProCinema 92").
