What should I use?
Discussion in 'Cables & Switches' started by mickyd67, Jun 30, 2005.
  1. mickyd67
    mickyd67
    Jun 28, 2005
    582
    +14
    I have just bought a Plasma HD TV, DVD recorder, and have Sky+
    Plasma is: Panasonic PV500
    DVD rec is: Panasonic EH-50
    Sky+ is just the standard (not 160) one
    I need help to understand which cabling to buy.
    I was thinking:
    Scart from Sky+ to plasma
    Scart & S-video from Sky+ to DVD recorder
    Component cabling from DVD recorder to plasma
    Would that be a suitable soultion?
    Am I buying too much/ not enough?
    Also - which manufacturer is best? Ixos?
    I've no idea - please help...
  2. mickyd67
    mickyd67
    Jun 28, 2005
    582
    +14
    Anyone?
    Please help
  3. apguy15
    apguy15
    What you have suggested is fine although there is no need to run a scart lead and an s-video lead between sky and DVD, the s-video signal is carried in a normal scart lead.
    As for cables just use the best ones your budges can stretch to
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,236
    The Borders
    +2,940
    mickyd67
    Your plan looks pretty sound - though I'd prefer to use S-Video + Stereo audio on 2RCA to 2RCA into the Recorder; a decent set of Audio cables has better conductors and screening than you'll get in a fully wired SCART cable.
    I'd also seek some opinions on RGB vs. YUV from the DVD Recorder - I find a lot of the Panasonic recorders look awfully soft on the YUV Output.
    Ixos gets plenty of thumbs up around here - we tend to supply and use Supra, VanDamme and BetterCables; check out the various banner adds around this page.
    apguy15 - SCART has the capacity to carry S-Video but SKY don't provide S-Video via the SCART Outputs.
    Best regards
    Joe
  5. mickyd67
    mickyd67
    Jun 28, 2005
    582
    +14
    Thanks for the help guys.
    Joe - I'm not sure what cables you mean when you say "S-Video + Stereo audio on 2RCA to 2RCA"
    Do you have a link to what that cable is/ looks like?
    I think I'll go with Ixos, as you say they get a lot of thumbs up.
    I'd quite willingly pay about £200 for cables (looks at though I'm going to have to anyway) as my set up cost neary 3k.
    Also - not sure what you mean by "I'd also seek some opinions on RGB vs. YUV from the DVD Recorder - I find a lot of the Panasonic recorders look awfully soft on the YUV Output."
    What's that mean, and how can I get around that?
    Anyway - thanks to you both for the time to reply.
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,236
    The Borders
    +2,940
    Hello mickyd67
    SKY - I'd use the Stereo Audio Outputs on the SKY+ box rather than the additional SCART cable; see below:
    S-Video - http://www.bettercables.com/5meter164feet.html
    Stereo Audio - http://www.bettercables.com/5met164feetp.html
    YUV 'Component' - http://www.bettercables.com/5met164feetp.html
    YUV vs. RGB - it may be worth sticking with RGB via SCART from your DVD-Recorder as often the conversion to YUV undertaken in the recorders makes your on-screen image look 'soft'; best to seek out opinions from a few owners of the Recorder you have; see the DVD Recorders Forum on this site.
    Best regards
    Joe
