What should I set gamma to when using VGA?
T
tricky1974
Hi, I'm using a panasonic 26LXD600 lcd and when I connect my 360 via VGA I've options for GAMMA 2.2 or 2.5 what should I set it to for best picture?
Saldawop
1) set it to 2.2
2) set it to 2.5
WHichever looks best is the one to go with :thumbsup:
Saldawop
You are more than welcome , my friend :smashin: ;)
runam0k
Whatever you set it to you're likely to change your mind once the update hits. It has all sorts of VGA fixes, apparently.
