what should I look for when assessing a dlp Pj - runco cl700
Discussion in 'Projectors, Screens & Video Processors' started by rahulkohli, Jun 30, 2003.
  1. rahulkohli
    rahulkohli
    i'm looking at the runco cl700, at the moment. what problems am i likely to encounter with it, if any. e.g. gray scale, rainbow, screen door etc.
    I viewed monster inc. on it and was deeply impressed. but the fifth element wasnt as good but still impressive.
    I need some advice on whether this is the best projector i can get for about £10,000. And what problems to look out for when viewing projectors.
  2. Anders_UK
    Anders_UK
    Projection Design F1!!! Without doubt one of the best single chip DLP's I have ever seen and installed.
    Comes in 3 flavours with Lens options, and will even recall timing files from user saved blocks (at my request too!). Even has a super fast colour wheel to reduce splitting.
  3. Jackass
    Jackass
    Jan 9, 2003
    3,402
    +811
    What separates this from the rest of the Mustang projectors?
    Can it take a 48Hz signal without converting back to 60Hz internally?
    Thanks.
    Steve.
