What should I go for?
Discussion in 'AV Receivers & Amplifiers' started by cdlse, May 26, 2003.
  1. cdlse
    cdlse
    want home cinema, but already have a DVD player so I really do not want to purchase a new 'all in one' pack.
    I have around £300 ($450?). My local hi fi shop recommends:
    A Pioneer (I want a compact system)
    http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=1601&taxonomy_id=62-98
    With Yamaha speakers:
    http://www.yamaha-audio.co.uk/speakers/package/ns-p230/index.php
    Not knowing much, do people think this sounds good? The speakers seem to have more power than the receiver - does this matter?
    If not I was going to bin the DVD and buy an all in one for the same price as the above.
    http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1194
    Any thoughts appreciated.
  2. sounddog
    sounddog
    Dec 11, 2002
    3,438
    107
    Leicestershire, UK
    +477
    The Pioneer / Yamaha combo will almost certainly sound better than the Sony DAV system, and will be more flexible if/when you want to upgrade later for any number or reasons.
    Would also be worth looking at the Yamaha 430 / 5540 amp to go with the speakers at around £180 for the amp from Richer Sounds.
    Vikki
  3. cdlse
    cdlse
    Thanks for the quick reply.
    Yes, I have the Richer Sounds catalogue in front of me. Unfortunately, with my DVD, Video and Sky Receiver, there is not much space in the old tv cabinet for the Yamaha. Which is why I thought I'd opt for the slim Pioneer!
    Nice to know that I can rule out the Sony. Looks nice, but I guess that distracts from the sound!
  4. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    i had the same problem with space so opted for the slim pioneer with slim dvd as well.Unfortunately i find myself upgrading already (a year) as the amp isn't powerful enough for my taste.
  5. cdlse
    cdlse
    newbie265,
    By 'isn't powerful enough for my taste', do you have loud taste or was it not even good at normal levels? My room is about 5m x 6m, and have neighbours on the side of thin walls (!), so would not probably crank it up.
    What are you looking to replace yours with?
  6. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    well its only 5x30 watts and and the more power the finer detail even at low levels .I watch a lot of music dvds so i want a bit extra.admittedly the speakers that came with my pioneers system are a problem as sats aren't too good for music.I'm looking at the pioneer 811 and the yamaha 640 and mission m73 pack.
