What should i get Sanyo PLV-Z3 or sony h50
Discussion in 'Projectors, Screens & Video Processors' started by activeuk, Feb 10, 2005.
  1. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    looking at getting my first projector the week end but what one would be best for me i will only be useing my pc with it to play movies games and xbox
    is there a big differnce with the 2 projectors is it worth the extra 500 for the sony
  2. azzo
    azzo
    Feb 13, 2002
    999
    Wokingham
    +9
    I baught a Sanyo Z3 last week (an upgrade from an AE100)
    I am pleased with it. I have not seen the Sony, but only you can decide whether the extra 500 pounds is worth it. Remember that you get a 3 year warranty with the Sanyo.
    IMO All LCD projectors have limitations. The blacks on the Z3 are no where near I would like, BUT if you are using it for games then the HiRes of LCD projectors is what to go for.
    I think you will be pleased with either if you have not owned a projector before.
    Plus points for the Sanyo -
    Noise. This is a very quite projector.
    User Servicability (means to clean panels)
    Warranty
    Resolution
    Colours - very realistic.
    Anybody care comment on the Sony.
    Azzo
  3. Member 14847
    Member 14847
    Aug 16, 2002
    491
    28
    +54
    Could you tell us a little bit more about your requirements? Do you have control of ambient light and will you be using a screen or wall? The more information you can provide, the easier it is to help.
  4. Supersonic
    Supersonic
    Jan 5, 2005
    932
    Surrey
    +87
    I'd agree with Azzo - the Z3 looks very good. If you calibrate it and can turn the lights off, the picture improves no end - I certainly haven't been disappointed with black levels/shadow detail.
  5. activeuk
    activeuk
    Jul 11, 2004
    80
    birmingham
    i will be useing a screen i have one window in my bed room that i can draw the certains on that is a about it
